- Replies 8
- Views 1.8k
Mopar1973Man 3 posts
Ravewolf 2 posts
dripley 1 post
Dieselfuture 1 post
Popular Days
If you have an accident and the fuel pump will continue to pump. I highly suggest having the ECM repaired so when the tach hits zero the fuel is shut off. After being to several accident scenes in not
I wouldn't do it unless I just had to. But would not leave it that way for the reasons above.
You can run a 24V ISB as a standalone with the ECM. Problem. If you want diagnostics or work OBDII port you need both the PCM and the instrument cluster. The PCM starts the CC
Just curious, but what would happen if one were to bypass the ECM and install a switch to turn on the fuel pump? Mine works fine, but I was always curious about it.
