2000 3500 no power,sucks fuel like it's free
Newbie here and I don't want  to beat a dead horse,BUT,! Here I go. Have a 2000 3500 dually, 5spd ,4:10s 185000 miles. This thing is useless,very disappointing TRUCK,but I like it!  On the same roads,pulling the same loads that I did with my 401 powered Jeep Cherokee. This TRUCK would never keep up! I have replaced the lift pump, injection pump, all the filters, clean the fuel system out, rebuilt the turbo, replace the gate valve. I have good fuel pressure, plenty of boost. Sucks fuel like it's free. Everything except for gate valve is stock.No exaggeration,,, it Hardly pulls my 1car trailor.Ready to burn it! I got it to carry my truck camper an tow my trailer with JEEP on it at the same time. Not gonna happen  HELP
  • Replies 65
  • Views 10.5k
    @Dieselfuture is right on the mark.  With Dieselfuture...   Quadzilla Adrenaline 7 x 0.010 Injectors @ 320 bar HX35/40 Hybrid (60/60/12) 4 Inch exhaust BHAF
  • dripley
    dripley
    I get ringht at 11.5 out of mine running the interstates aroind 65 mph . Grossing right at 23k like this.
  • Whats the difference in buying a pretty cheap membership or making a donation. The money goes to the same purpose.
Truck looks good.
If truck really has less than 100k I thi k I'd sujest a quad programmer first. If truck had 200k I'd say I injectors first.
That's a good looking truck
Mopar man has helped out the dodge guys alot. Many have helped him to.
20 hours ago, Mopar1973Man said:
Still the same method. Just spreading small amount by all.
https://mopar1973man.com/subscriptions/
I reupped again but not sure how much that helps if it goes for the site.  I would send a check directly if I could.
Yes it all goes to the site. I only get a cut of what left over after bills are paid. If the income is low I lose a paycheck or its really skinny like April of $20 for the month.
Check cost me a 250 mile round trip to the bank to process. No longer have a local bank. Then I need to transfer the funds from my personal account to M73M Paypal account.
When you use the debit card. I don't have to drive 250 miles to a bank and back and then I don't have to transfer funds. Its directly deposited in the Paypal account. Much easy for the bookkeeper to keep up with.
9 hours ago, Evan said:
Truck looks good.
Thank you.  All indicators I have including title check/car fax & seriously looking it over for tell-tale signs before buying the mileage is accurate. So you think I should change it from a Smarty3 tuner to a Quad (I  assume you mean quadzilla)  ?
Everything I read about Tuners Smarty3 was the choice for best and/or practical mpg, etc. (Until I bought it & had it installed then I found 2 respected opinions mentioning the Quadzilla as a possible better choice.
My list is so long now of wanted maintenance & upgrades.  Dowel, electrical interference (converter lock), transfer case support (supposedly a mount that fits GM will work in a direct fit), cooling system bypass, transducer etc for the Tranny  and on & on.
Smarty S-03 is very limited tuner. No adjustable timing or fuel maps for larger injectors. It was design around a stock injectors. Quadzilla has full fuel table control and timing control to fit your fuel system. Like Smarty S-03 limits to 19° BTDC for timings for most settings. Like Quadzilla and 7 x 0.010 @ 320 Bar injectors I run 24° BTDC timing which cannot be done on Smarty S-03.
