Can’t stop the ac noise
- Replies 17
- Views 5.9k
skyhigh4by 7 posts
Mopar1973Man 6 posts
Dieselfuture 2 posts
rambo 1 post
Popular Days
Unhook your alternator and test again. Might have replaced the diodes but the brushes, slip rings, etc can still cause issues. Then the output speed sensor on the transmission could cause
I'm just trying to find your source of the noise. If the alternator is removed then the noise should drop to ZERO or nearly. If so that just proves the alternator is still having issues. If you measur
The numbers look good and acceptable. I would say the electrical system is good but you might talk to @Dynamic ask him about the lockup issue he might shed some light on it too.
W-T ground mod done, replaced alternator diode pack, and cleaned up and coated all grounds I could find with dielectric grease.
Im still getting 0.033v at idle and I’m still having a lockup issue. My tc tries to lock early(40mph)under light throttle and then instantly unlocks until I gain a bit more speed and then will lock up again.
