Hard start in morning, then good rest of day
- Replies 37
- Views 7.1k
Liviniuk 15 posts
Mopar1973Man 10 posts
dripley 5 posts
Rotax3006 3 posts
That did not fix my issue either, it just got me by untill I could find the problem. With what you have already done my money is on the return line on the back of the head or the tee below it. It does
You might want to get in on the injector raffle!
2 months later...problem solved... Believe it or not...the only damn hose I did not check or even thought of was the fuel pressure gauge hose....it rubbed a pin hole leak from vibration....finall
2001 6 speed. So here's the story. Lately when the truck sits over night it cranks 10 seconds if not more to start. Rest of the day is no issue. I've got 20psi to the vp44. I've parked nose down. I've checked every bolt and fuel line. I've checked and load tested the batteries. Batteries are a touch on the weak side but not bad. I cannot for the life of me figure it out. Fuel tubes and injectors were pulled and re o ringed ect. A year ago. Any ideas? I'm honestly down to replacing the vp44 check valve and the fuel heater on the canister o rings. I understand its losing prime somehow but I'm having a hell of a time finding where. Once it fires up its bump the key and it pops. I'm going to pull the LP fuse next and see what happens. If that dosent help I'll pinch off the return line before the tank and see what happens. Any insight would be great.
Vp44 is less than a year old. Wait to start light works as it should as per normal. No excessive smoke ect. Turn the key to on and LP kicks on for the split second as per. Truck runs / sounds as normal once it starts in the morning. Cannot figure this out.
