- Replies 20
- Views 4.3k
Bojon 9 posts
Mopar1973Man 5 posts
Me78569 3 posts
NorCalAndrew 1 post
no issue that I can see. Like Moparman said it looks like you are hitting light throttle limit and timing is being pulled to help get things moving. If you dont want that behavor then l
I've been having an intermittent issue with my truck, runs great but occasionally it will cut out momentarily. Seems like its also when lightly accelerating in second and third gear. I was able to snag the data from my Quadzilla when it happened to me today. Everything looks normal to me except the timing. If you take a look at the graph the timing will suddenly drop out, down to around 13°, this is when the engine cuts out, and then bounce back to 18-19° and run normally.
When looking at these graphs am I seeing what is actually happening, or what is being commanded? Other than this little issue that has happened a few times in the last few weeks, the truck has run like a top. I'm concerned this may be a VP issue.
