- Replies 35
- Views 8.7k
Red Rambler 13 posts
IBMobile 5 posts
dripley 4 posts
Mopar1973Man 3 posts
The last one I did was @JAG1 's work truck where we pulled the dash and HVAC box out. Before disconnected the wiring and vent hoses: turn the ignition switch to the on position
Itmis not as bad as you think. I did mine several years back using @Mopar1973Man article. Replaced the the dash and rebuilt the HVAC box too. I spent 3 days as I remeber. But it could be done 1.5 or 2
Found mineral oil here to be the least expensive. https://www.oreillyauto.com/detail/b/murray-climate-control-4379/chemicals---fluids-16461/air-conditioning-chemicals-16497/refrigerant-oil
Since warm weather is just around the corner I need to get my A/C fixed. I filled it with new coolant and it lasted good for a month, but it eventually leaked out. I used the leak test stuff that you put into the AC lines and you use the glasses and the light to check for leaks however did not find the leak. Where are the most common places to check for leaks or even replace? I thought about buying a new seal kit but wanted to get some opinions first. Thanks all.
