- Replies 14
- Views 2.6k
Mopar1973Man 4 posts
015point9 4 posts
IBMobile 2 posts
Dieselfuture 1 post
Popular Days
I honestly don’t have any experience with these specific products but the vertical or horizontal lead should be fairly obvious. Do you have a picture of your current alternator? I have a 99 and if I r
This may help show the difference.
The larger cable on your pic appears to be coming out the side not the back. So I think the bottom pic you posted with the all flat module is what you would need.
Is there a way to tell which Denso diode I need... by looking at the alt is still hooked up?
Like maybe that threaded bolt coming out is in different spot?
Edited by 015point9
Add pic's
