ABS/ Brake light on/ Cruise control doesn't work
- Replies 17
- Views 6.9k
Mopar1973Man 5 posts
Blueox01 5 posts
JAG1 4 posts
dripley 2 posts
Ok. First off the ABS module is reporting ABS and BRAKE light. This is a speed sensor error. There is 3 speed sensors 2 sensors in the front axle and 1 sensor in the rear axle. There is a
Never mind Cruise is working, not sure what fixed it, put some dielectric grease on plug, works now.
Thinking the rear ABS speed sensor is also used for setting cruise, can't see it connected in wiring diagrams, must be in PCM, am I correct in thinking these are related problems?
