Clutch not disengaging intermittently
- Replies 38
- Views 11.9k
dripley 14 posts
Ironforger 12 posts
Tractorman 4 posts
Rotax3006 3 posts
Will do! I'll clean & polish that shaft without removing too much metal. Maybe I'll get my girlfriend to do it! She's a talented shaft shiner. The bushing is made with "Oilite" bronze. It'
Maybe this one is to big???
I'm running right behind him at 384k miles. Still kicking out about 1,000 miles a week. These engines are good for 1 million miles. I'm on my second clutch. South Bend Con OFE clu
02 3500 dually 6sp nv5600 quad cab 2wd independent suspension approx 230k miles. It has the 5.9HO.
I've had this truck for about 6 years, never had any clutch issues. I don't know the full history of it so I'm assuming it may have the factory clutch.
This weekend I noticed it was hard to get in gear, like the clutch was not fully disengaging. I was towing a trailer for a couple days (not really a huge trailer, 10ft enclosed single axle, not really too heavy or loaded etc, prolly 3000lbs total).
Clutch issue started after I had backed in and parked / disconnected the trailer. After I pulled away, I noticed it was hard to get in gear. I thought maybe I heated the clutch up a bit when I was backing the trailer in, can't rule that out.
So anyway, I shut the truck off, put it in gear, then started it while holding the clutch pedal down. Truck nudged forward a bit, then it was fine. I managed to drive it home, but along the way it was acting up, same issue, sometimes hard to get in gear like clutch was not disengaging, other times it seemed to act perfectly fine like nothing was wrong.
Thinking probably best to drop the trans & see what's going on. If I do, I'll definitely replace the clutch and throw out bearing. Do these trucks have actual ball bearing pilot bearings? Or are they bronze bushings like the old school days?
Any recommendation on which clutch kit to buy? I'm not running any performance mods right now, but sure would like to in the future, but nothing too radical. maybe either a tuner, performance injectors or both. Also may do an engine brake too.
By the way, I do my own work and I'm very particular and detailed about everything, clean install, proper torque values etc. I'm not trusting some dumb-a$$ shop to work on my machines
Thanks
