Borg Warner sxe300 62 65 14 turbo :)
- Replies 81
- Views 20.3k
Evan 44 posts
98whitelightnin 13 posts
Mopar1973Man 10 posts
Me78569 9 posts
You can' t compare psi between 2 different sized turbos. psi to psi the 62 is going to flow more cfm.
Again a gateless turbo is either going to not reach boost until too late in the rpm band to be useful or you are always going to be overrunning the compressor and risk blowing it up due to overspeed.
a 62/68/12 is good for 200+ hp injectors with proper tuning or 7 x .010's without I wouldn't even consider running that turbo with 50's lol. with proper tuning 7 x .010's are GREAT for a stock h
I'm getting payed pretty good to build a dump truck. My truck runs prett toasty pulling grades when heavy. Empty wich it is 99% of the time fine.
Running smarty on 9 3 3 7x09 smoky doesnt matter where smarty is set..
Was thinking head studs turbo and 3peice bd manifold in one wack. 7x10 injectors later.
What gateless turbos are available? I've looked alittle and see delete plates but no turbos built gateless.
My turbo hy35 is making a fluttering sound lately that's a new sound. Might be rubbing the wheel.
Or should I love with the higer temps and get some .320 injectors to possibly clean up smoke . Would my temps go up I'd bump up to the 7x10s
I'm not going to do a quad yet. Smarty is working well making very good power. I'd like to get the mechanical side first. I can't blame it entirely on the smoke. I've probly got 50k or more on these 7x09 sac injectors.
I'll will do a hx40 vband and may fab a 5" down pipe. Been rding up parts to do the down pipe. Probably just by a hx40 pipe. My time lately is scarce to come by. Its spent burning up the freeway
Thanks for the ideas on this
Edited by Evan
