- Replies 28
- Views 5.5k
William Smith 7 posts
dripley 5 posts
Dieselfuture 4 posts
NIsaacs 3 posts
I had a car with an ABS code for the left rear wheel sensor. I found where a rat had chewed through the wires at that sensor. I repaired the wires and retested. The code for the left front sensor ca
2001 24v cummins. I started having this problem a couple weeks ago. I've changed both speed sensors. I've pulled rear diff cover and checked tone ring. I had batteries checked and had one bad one so I changed them both. I've checked ac voltage from alternator. does anyone have any ideas on what to check?
