Grid heater bypass warning
- Replies 16
- Views 3.8k
Gregturley 5 posts
dave110 3 posts
IBMobile 3 posts
015point9 2 posts
Popular Days
It's great that you posted your experience and are informing others of the danger. A year from now this thread will be 5 pages or more from the front and I don't think to many people will see the war
Great thread for a great forum. Wouldn't of turned out like this on other forums imo.
@015point9 you're right. I've seen posts on other forums go completely sideways because a post like mine was not taken well. After being here for about a year i didn't think that would happen. I was i
A couple of weeks ago i did @IBMobile grid heater bypass. Everything worked great with no issues. This morning when i went to leave for work i turned on the grids. Fired up the truck, everything normal. Turned off the toggle switch for the grid heaters while the grids were powered up. Started driving and noticed my digital volt gauge was dark. Didn't think too much of it. It was cheap and figured it just died. Shut the truck down at work and realized my turbo timer was also not working. Checked everything and both volt gauge and turbo timer are fried. Took a little to put it together but i believe a current spike from the SS-581 solenoid destroyed them. I did some research and Standard says "do not use on vehicles with a computer. Damage to the EEC WILL occur. Cars with a computer require a solenoid with suppression diodes." I looked through Standards online catalog and found SS-598. It is rated at 300 amps and used on later model Fords and Mopars that have computers. Nothing in the literature about not using on computer cars.
If anyone has a BD Diesel Cool Down timer 2 for sale cheap let me know.
Edited by Gregturley
