I’ve been trying to get rid of this fault code for years. I have done lots of resistance/voltage tests and I’ve tried like 3 different PCMs
Any and all help is greatly appreciated.
Edited by rts.dst
  • Replies 15
  • Views 2.8k
  • watch yourself boys,  the dirt can turn real mean real quick       OP,    how are you reading this code?
  • To the OP. Your subject mentions a 118 code. I dont see that code in data base here. Can you enlighten us to what the problem is?   And to @JAG1. I did not know pertinent and wood pecker wen
  • Dieselfuture
    Dieselfuture
    I'm sorry I can't help you out, but your twin may have the answer @Me78569
I cant help either, but @Dieselfuture hit the nail on the head about your twin. Maybe he can help.
Now we both get banned, along with @JAG1 The Troll Army is growing
What fault code are you seeing and what are the symptoms?
BTW, Dieselfuture is head troll, but I try staying pertinent to the subject between pot stirring  of chicken soup for Dripley :stirthepot:
And to @JAG1. I did not know pertinent and wood pecker went together.:tongue:
Edited by dripley
OP
@dripley
i am reading this via cheap Bluetooth scanner at the moment, but I have borrowed expensive scanners from friends and they show the same thing.
P0118-Engine Coolant Temp sensor 1 circuit voltage too low
Edited by rts.dst
Does your dash gauge work for collant?
Edited by Me78569
Yes. I even replaced the sensor for the heck of it
6 hours ago, dripley said:
Is the temp reading correctly on the gauge?
@dripley
yes...
Fixed it
  • 3 months later...
On 11/14/2019 at 9:30 PM, JAG1 said:
What did you find wrong?
I went to O’Rielleys and bought a coolant temp sensor. They had one designated for the pcm. I plumbed it in above the thermostat housing and ran a couple quick wires to the plug that sends that to the pcm.
