Doing more ball joints
Time to just get the right stuff.
  • Replies 9
  • Views 2.3k
  • I warmed control arm with a little torch joint pressed out easily.  Before warming it didnt seem like press was going to push it out.   Lots of good ways to do it   Heat is dangero
  • Dieselfuture
    Dieselfuture
    Should do it, but the ball joints studs will need to be cut off to them out with that kit. You'll see why.
The only problem i had with a similar set on mine was lowers. It did not come with a receiver cup cut on the right angle to fit the knuckle. I had to beat them out. It was fine for installing them though. I did not have cut any of the studs either but maybe mine were deeper. I guess you will see when you do it like @Dieselfuture says.
I've cut the studs before.
These are GM trucks well see how it goes
Might be easier to take a torch blow a hole through the ball joint, push the stud out and then using hacksaw like score the cup and hit with a hammer it will fall out. No more fighting for me. So much easier to remove stubborn ball joints.
I I thought using torch on ball joints was a dangerous idea
Yeah, I had to make an adapter to make mine work. A longer tube if you will. The rest of the stuff works well though.
My lowers required a cup cut to a specific angle to use for removal
Heat is dangerous though but I often use it and pray
