Heater Blend Door Issue
- Replies 35
- Views 8.6k
int3man 15 posts
dripley 7 posts
Tractorman 5 posts
JAG1 3 posts
Be sure to test the batteries individually not paralleled. About the heat you need..... Tractorman is right you need to pull the dash and get the HVAC clamshell plenum out. There are sever
If my memory serves correct, and that is a big if, I think you were cleaning the junk away from the evaporator core since the evaporator core is the next item in the path downstream from the blower bo
Hi All, Got in the truck to get the Christmas tree we are having our first good storm of the year in Northern CA. So we drove with no defrost and foggy windows. Reading the trouble shooting options the hoses are both Hot with the right being hotter, no hot air blowing anywhere If you turned off the fans and idled I did feel some heat but not enough to warm the cab. Looking at a trip to Seattle at Xmas time this isn't going to cut it.
Is the Heater Treater still the hot ticket for this issue?
Thanks Cold in the Central Valley!!
Michael
Edited by int3man
Typo's
