Bucking at 40 to 50mph
- Replies 22
- Views 6.5k
Me78569 9 posts
Collinst15 8 posts
Mopar1973Man 2 posts
kzimmer 2 posts
Go wot from take off. Mikes tune is made for 7 x.010's you are running a good bit less fuel than that. I am guessing your offidle fueling is causing your issues. Too little fuel will cau
So how it works sub 1200 rpm if(RPMS > idle_limit && TPS > 2)// && RPM > 850) { idle_limit = 600; // RPM low limit fuel_trigger = 1
Mine definitely was because of this it is now a slightly noticeable shutter. Just hate that trans started to act up. Always something Tim
Good afternoon everyone,
I did some searching on the site before posting, but would like some other insight. My truck bucks between 40 and 50 mph and rpms are around 1100-1200 on level 2 and 3; I have not gone above level 3 as pump is not tapped. I feel it may be timing related as it did not buck today when I had the Quad on level 0. Current tune set up is below. Do you guys have any suggestions where to move timing to stop the bucking?
Tune: Mopar1973man Economy Tune
Max Load Timing Offset: 1 degree
Low PSI Timing Reduct: 3 degrees
Timing Reduct Scale: 40%
Light Throttle Timing Adv: 1 degree
Light Throttle Load Limit: 25%
RPM Timing Max
1500rpm: 14
2000rpm: 16.5
2500rpm: 19
3000rpm: 21.5
Max: 24
I attempted to data log today, but closed app before I could import data. I will get data tonight when I leave work.
Thanks,
Tim
