- Replies 11
- Views 2.4k
Doubletrouble 5 posts
dripley 3 posts
01cummins4ever 2 posts
IBMobile 1 post
Popular Days
You may be losing prime over night. Try parking truck facing down hill. Wind chill temp has no effect on inorganic material; it's the actual temp that matters.
Ok, this morning the temp is 15°F. Went out turned the key on popped the hood and felt for heat at the grid heater, seemed to be warming. Cycled the key to run the grids a second time then cranked and
So this morning the temp outside was 14° F and I went out to fire up the truck so she had time to warm up. It started but reluctantly. I am new to this diesel truck world other than the large semi trucks. This is how it went:
Turned on key got the wait to start light, waited for it to go out and cranked the motor, as soon as she started to fire I let the key go, she died.
Cycled the key, WTS light went out and cranked again. This time she fired I held the key to start a bit longer. Thought it started to run, she died.
WTS light again, then cycled key, WTS light a second time, cranked til she took off. She ran then.
Grid heaters are working from what I can tell (after it's running lights dim, amp gauge drops when they cycle).
Am I doing something wrong here or could there be a problem? How easily or difficult should it be to start at about 14° (real feel was 4° with wind chill, truck was facing into the wind as well).
With my lack of experience with the dodge/Cummins combo I don't know if there is something I may be doing wrong or should do differently or if I should be concerned at this point. Thanks for any replies!
Also, just some extra info, the lift pump does run, checked the fuel pres. Not long ago, had 18psi at idle.
