Bad mpg with quadzilla tune
- Replies 39
- Views 6.5k
Evan 10 posts
Mopar1973Man 8 posts
Voltronics 8 posts
Me78569 5 posts
You are working the truck pretty hard at 70 with that setup. The guys getting 20 mpg have stock height stock tires and are typically doing under 65.
Ooohh wee, Quadzilla ain't going to fix that. @Evan might though seems the set up you got is up his alley.
I can 19.5 at 75 on 265 75 16 and no lift. You are turning a lot of rotational mass and way up in the wind. @Evan would be the man on your set up.
I’ve been getting about 13mpg on highway with speed steady at 70mph. I’ve been seeing/ hearing people talk about getting 20mpg and wondering if I can achieve that here is the tune I’m cut using
Tune
Tune
Rpm timing
Fuel
Fuel
