over 2000 rpms sometimes lose of power , no pedal response
- Replies 13
- Views 2.7k
JAG1 4 posts
dripley 3 posts
Dieselfuture 3 posts
kamododragon122 2 posts
Popular Days
What @dripley and @JAG1 said. Here is the W-T modification.
The 216 is the code I was speaking of. It is a mechanical failure of the timing piston inside the pump. You have symptoms that you describe in the title of the thread and the code. The VP is dying.
Probably apps, get a timbo. Check all grounds, do WT mod, pcm protection mod, check ac noise.
hey guys i have a 1999 dodge 2500 24 valve , at times if your are in the throttle above 2000 rpms the engine just cuts power then u have no pedal response even if you push it all the way down , but how ever if u let up for a split second the power comes back like nothing has happened at all. i do have the code p1693 in the computer i have not tried clearing the code yet . if any one can point me in the right direction please let me know thank you.
