Quadzilla adrenaline transmission slip
  • Replies 17
  • Views 6.5k
  • Good information above, but an important piece missing. If the number wasn't accurate, yes, your tire size and gearing settings may need adjustment. However, where are you viewing this number, and are
    Already posted above...
  • hdpwipmonkey
    hdpwipmonkey
    Circumference = diameter times Pi or in your case C=35(your tire size)x3.14(Pi) or as stated above... Its nice to know the math behind the answer so you'll know how to calculate
What settings did you configure for your vehicle setup in the quad app?
9 hours ago, Project_blackgold24v said:
The quad is saying that the transmission slip is at 100% but transmission seems to be fine  no problems
Are you talking about like the tire size and trans  and what gear ?
47re for trans and for tire wasn’t really sure on what size to put  I’m running a 35/13.50 I looked on the page to see what someone was tuning said he had a leveling kit with 33 think it was in the 90s so I went a couple numbers up and I looked up in the axle tag for the gears  I can look when I get off and let you know the
numbers for sure
Circumference... 109.9" roughly.
3.55 or 4.10 are the standards.
Just for fun the 245/75 R16 I'm running is 95.7" for measurement.
Those settings need to be correct for trans slip to work,
yes prob.  Just verify your settings are correct.
54 minutes ago, Project_blackgold24v said:
Okay will do  and I have a ? On the tire size how do you convert that to get the right number
or in your case
Its nice to know the math behind the answer so you'll know how to calculate it again if you change your tire size :thumbup2:
Good information above, but an important piece missing. If the number wasn't accurate, yes, your tire size and gearing settings may need adjustment. However, where are you viewing this number, and are you moving at the time? If you aren't moving, transmission slip will always show 100%, because the engine crank shaft is turning, and the transmission output is not. 100% slippage until you start rolling. Similarly, if you look in the data log screen of the iQuad app, you will see %100 slip reported as the max slip every time, assuming you were stopped the last time you cleared the logs.
Does that make sense?
To add,
As far as I understand, the iQuad tire size settings are only useful/accurate if your truck's cluster speedometer is NOT accurate. For example, if you have oversized tires, and you had a tech with a Chrysler tool correct your tire size to make your speedo accurate, then you need to leave iQuad at the default tire size, or it'll throw the iQuad speedo out of whack. And I assume trans slip.
Edited by kzimmer
Double post formatting
10 hours ago, Me78569 said:
The quad needs circumference  as 35" is no enough to calc the slip %
8 hours ago, hdpwipmonkey said:
its nice to know the math behind the answer so you'll know how to calculate it again if you change your tire size :thumbup2:
Or plug your tire size in and get other info too.
