Built 47re 2-3 Bind Up Help
Hey guys, first post! Stoked to be here. Anyways... I bought my truck about 2 months ago and it came with a built trans from Hartnell transmission in Redding. I proceeded to snap the Billet input shaft Which was obviously defective, and this was repaired under warranty that was thankfully transferred to me. They replaced the converter, pump, put in an Aermet shaft that I paid for, and cleaned out the rest of the trans. While the trans was out I had them put in a billet accumulator and 2nd gear servo, 4.2 ratio lever and billet anchor and strut (TCS combo kit). Before this work, the trans shifted great. Now that it’s back in, the 1-2 shift is super fast, near instant and very firm. Perfect, in my opinion. The 2-3 shift has an obvious bind up where the truck slows momentarily before the shift. Once the shift actually happens, it is firm and quick as well though not as good as the 1-2. All other shifts are great, no problems downshifting. I’m going to loosen the band again to see if this helps but it didn’t seem to have any effect when I adjusted the band the first time. The trans stays very cool so I don’t think anything is dragging when it’s in a gear. I used Dex/Merc with a bottle of lubeguard black. Would the band adjustment be different with the 4.2 lever?  What would be my next steps in diagnosing this bind up?
  • Replies 32
  • Views 11.5k
  • What servo was used?   What do you mean by "no slack" in the TV cable? How did you adjust it? At what RPM does your WOT 1-2 shift occur?   EDIT: Also, how is your front band adjust
  • Ughhh... And the prices these corner transmission shops charge people for these "built" transmissions. SMH... I digress...   There are 3 Sonnax valves on the invoice, which basically aren't
  • OMG... And they sold you an Aermet shaft? You don't even need a billet shaft at all at that power level. And 900 hp? Ummmm... NO. I'm going to shut up before I say something I might regret later, but
Isnt 122 alittle more pressure than stock. And about 50s at idle
Also noticed TC lock in 3 and 4 is different.
Should it be?
Edited by Evan
Should it be?
No, just a stock spring that's probably wound up a bunch, which can also be problematic. Most likely this guy's version of  a "high performance" setup.
It's not uncommon to have 3rd and 4th be a little different, especially with a 47RE
10/4
Mine runs almost the same locked in 3rd and 4th. Close enough I'd call it the same.
When it sees ove the the 95ish could his computer be having issues?
Depends upon a lot of factors, not the least of which being pump volume. By the time you get the 3 clutches on, pressure on both sides of the intermediate servo, and the converter locked, a 47RE pump is up near its capacity, especially if there are excessive losses in the system, and/or excessive clearances in the pump.
Line pressure in my @Dynamic rebuilt transmission.
Air temp 91°F  Transmission fluid temp 165°-190°F
Line pressure, transmission in drive :  no throttle  stopped   85 PSI
                                                          light throttle  2ed gear 105 PSI
                                                          light throttle  3ed gear  110 PSI
                                                          light throttle  4th gear   120 PSI @ 2200 RPM
                                                          W/O throttle  1-2 shift   180 PSI @ 2800 RPM
                                                          W/O throttle  2-3 shift   175 PSI @ 3100 RPM
                                                          W/O throttle  3-4 shift   150 PSI
                                                          W/O throttle  4-3 shift  150 PSI
                                                          100% throttle 4th gear TCC locked @ 70 MPH 160 PSI
                                                          0% throttle 3ed or 4th gear TCC locked down hill slowing 100PSI
                                                          reverse gear stall test 330 PSI
So are you telling me I’m screwed here with a $5500 boat anchor in my truck that doesn’t work right? The pump is new, is there a way to test the output of it through any of the test ports on the trans? It would likely be almost $600 just to ship it to you and back so that’s not really an option and from what you’re telling me most trans shops aren’t worth **** for getting this thing right so do I have to tear into this thing myself and check clearances or what.
I think worst case scenario you might need some valve body work. I'd love to get Dynamic to work mine over, I had a local shop do mine and they did a terrible job. Gave it to me with the pressure turned down way too far among a lot of other issues. I turned the pressure up and made it work. If I was you I'd do some reading on pressure adjustments and increase it until you're happy, and go from there. I have a bit of a 2nd to 3rd bind at the moment as well. I ended up tightening up the TV cable a little bit and it helped a little, but I'm probably going to loosen the 2nd gear band half a turn first to see if it helps. I'm using the TCS Products kit as well.
There are good shops
Dynamic happens to be one that's computer savvy.
There builders youl never hear of in your area maybe even working out of they're garage.
Look towards small shops race car guys. Sled pulls
Not necessarily. I'm just telling you that someone didn't setup the transmission correctly. Assuming that the direct clutch clearance is in a usable range, it can probably be fixed by reworking the valve body and intermediate servo.
I'm not trying to make blanket statements about all transmission shops. What I AM saying is that modding a 47RE/48RE transmission is a LOT more than just jacking up the pressures. That's a part of it, but even within that, there are good ways to do it, and not so good ways of doing it, and ways of shaping the pressure curve to better suit the needs of the diesel engine that, quite honestly, the average bench build guy at the local shop will not understand. They can follow "shift kit" instructions, and that's where most local shop builders stop. Unfortunately, you didn't even get that. They just threw some Sonnax valves in it and sent it down the road. That is unfortunate...
I'll agree with that. I had a local shop build my valve body before doing my own research. I thought I would put my faith in a local "professional". I won't get into details but my valve body is a POS. If I every have disposable income again I'll have it dealt with.
I’m in the same situation, I had my trans rebuilt while on a road trip last year, (crapped out along the interstate in Kansas) rebuilt at a corner mom and pop trans shop in mid town America, It’s working fine for now but in order to hold up to my abuse it’s going to have to have someone that I can trust tune and modify it. But it did come with a genuine mass produced rebuilt single disk billet converter and sonnax valve body kit.  Woohoo.
@Reaper22 I also have the TCS 4.2 lever and have been experiencing a 2-3 bind in certain situations, no doubt due to a poorly calibrated valve body. When I set my band, I used the factory procedure. Today I decided to loosen the front band adjustment about half a turn, and it made a huge difference. It is now pretty much gone. I locked the trans in second gear and tried to make it slip, just in case the band was too loose, but it seems to hold as good as before. Of course a properly calibrated valve body is best, but this worked for me, and will hopefully hold up strong until I feel it appropriate to spend money on a valve body. Your experience may vary, be careful.
