- Replies 33
- Views 6.2k
kzimmer 7 posts
Unreal Summit 6 posts
Bullet 6 posts
Dynamic 5 posts
The main reason to use an aluminum pan is to strengthen the bottom of the case. There is literally no structure down there, and a good, heavy aluminum pan will strengthen the case by a pretty signific
I was gonna say exactly this ^^^. There has been many debates on where to read from...pan or hot line. And there's pros and cons to each one. But I thought it best to read from the hot line...so I
I have my sensor installed in the line between the transmission and engine coolant heat exchanger. This is the hottest you will see the fluid. You will then be able to react to the driving conditio
So I know it's been asked but I can't find the answer to satisfy my question. I got a quadzilla with the trans temp gauge in the port in the passenger side of the trans. It's starting to warm up here finally. 74 degrees and I was in the drive thru waiting on my wife's food. Well the temp kept climbing to about 157. I know I was sitting still and the temp came back down when I got to moving. But I don't remember it being that high last year. Maybe I just can't recall right or I am just being paranoid. However any help or calming words would be awesome! Lol. Bout 20 mins of driving and the temp is starting to show going down the road. Max is about 130-140 ish going down the road.
