- Replies 16
- Views 2.3k
Found the problem. It was a bad ground. Thanks for the help. This is a great site.
The ground was located in front of the left side battery box down in the bottom. A real fun place to get to. Mine had about 11 wires attached to one stud. After seeing it, it was no wonder I was havin
Loki, You should start a new thread.... BUT the ground for the headlights is G201. (this is a 2001 manual but yours is probably similar. The headlamps are sent constant
Hello,
I have 98 dodge 3500. The left headlight is dim on both beams and I checked the grounds replaced the bulb. It only has one fuse and the right light is bright. Sockets are not corroded but the dim light is 7 tenths of a volt less then the right one measured at the socket. Could the headlight switch be causing the problem? The dimmer switch seems fine.
