Boost sensor location?
- Replies 37
- Views 10.5k
Dieselfuture 10 posts
Ironforger 6 posts
Mopar1973Man 5 posts
IBMobile 5 posts
FROM SOUP TO NUTS
Ok I finished setting up my gauges. I went with a couple of brass reducer bushings in the port as @Mopar1973Man suggested. Took a highway ride, some gauge readings as follows. Please comme
Simple... 3/4 pipe plug is where it goes. Just behind the fuel filter you can see my tubing.
Hey Guys,
Finally getting around to setting up my boost / egt and fuel pres / trans temp gauges.
Whaddya think guys? what is the best recommended location for the boost sensor? I'll be drilling / tapping 1/8 npt so I'm hoping / wondering if the aluminum intake just before the manifold would suit. Easy to take off without worrying about drill / tap chips getting into the intake.
I got all of the other sensor locals down. And yea, I know about drilling/taping the egt probe hole while the engine is running. Done that a few times on previous vehicles.
Thanks!
