Hi All,I've been getting occasional 0216 codes since January. Today it took a long time to start and then wouldn't accelerate at all. Idle sounded normal, but it just stumbled when I pressed the pedal. I pulled the codes and got 0253, 0251, 0216, 1688 and 1693. Looks like its time for a new injector pump, and a new fuel pump, and oh yes, gauges.I'm thinking a stock VP44, Air Dog 100 and fuel pressure, pryo and boost gauges. Anybody have any good or bad experiences with any particular vendors? Thanks
  • Replies 32
  • Views 6.4k
The injector return on a 24V (VP or CR) runs out the back of the head, so you need to "T" that into the VP return line somehow. A OE canister eliminator kit is an easy and clean way to do it. On the topic of the AD, what does the drain on your f/w sep look like? Plastic know or metal "T"?
So the injectors return fuel too, cool. On the AD, its a metal "T". And the bracket isn't right angled like on Mike's install, the AD mounts parrallel to the frame.
that is how mine is installed. no problems so far. if you left the stock return line in place then there is nothing left to do. the return path has nothing to do with the fuel canister.
The metal "T" is good, thats the new improved filter. And I was thinking 3rd gen when I mentioned the canister delete. That piece is not necessary on a 2nd gen.
I've driven about 200 miles and at least 20 start/stop cycles since the VP44 replacement, and the CEL is still on. I disconnected both positive battery terminals for about 5 minutes, no joy. I tried pulling the codes, and there weren't any.Any ideas? Thanks!
How are you trying to pull the codes? Key trick will not work on your year truck. If you have a code reader you should be able to clear it that way. If not go to a parts store and have them check for codes. Disconnecting the cables will not clear the CEL.
I've driven about 200 miles and at least 20 start/stop cycles since the VP44 replacement, and the CEL is still on. I disconnected both positive battery terminals for about 5 minutes, no joy. I tried pulling the codes, and there weren't any. Any ideas? Thanks!
Sounds like you need a code reader to turn it off.:thumbup2:
I have a Davis Instrument Carchip that I've used on many ODBII systems to pull codes and reset CELs.I've used it on this truck to pull codes, but this is the first time the CEL stayed on after a repair.I'll see if a parts store can do any better with their reader, maybe its time to upgrade.Thanks.
I went to a couple parts stores and got the "Oh we're not allowed to clear codes, you'll have to go to the dealer". Apparently, some people would get their CEL reset just before getting their emissions tested. You'll fail right away if the CEL is on. I explained to the guy at Pep Boys that I had a diesel and didn't have to get my emissions tested. After a little hemming and hawing, he agreed to clear the codes. And the CEL hasn't come back on.Since my current reader won't reset the CEL, I'm looking for a new one. Does anybody have any experience with the Actron CP9575 ?
Ouch... Now pull the battery cable and retrain the APPS sensor... When you pull the battery cables you loose the APPS setting but the DTC's will remain forever... http://mopar.mopar1973man.com/cummins/2ndgen24v/apps/apps.htm (Bottom of the page)
I went to a couple parts stores and got the "Oh we're not allowed to clear codes, you'll have to go to the dealer". Apparently, some people would get their CEL reset just before getting their emissions tested. You'll fail right away if the CEL is on. I explained to the guy at Pep Boys that I had a diesel and didn't have to get my emissions tested. After a little hemming and hawing, he agreed to clear the codes. And the CEL hasn't come back on. Since my current reader won't reset the CEL, I'm looking for a new one. Does anybody have any experience with the Actron CP9575 ?
Hey just spend the $59 and buy this one http://www.ultra-gauge.com/ultragauge/index.htm It says it clears codes or do like i did Harbour freight for like $62 works good on my 02 model
Good call!! I have to retrain the APPS because I had disconnected the batteries, right? Not because the APPS was unplugged during the VP44 replacement.
Actually if you disconnect the APPS sensor or the batteries you suppose to re-calibrate the ECM again by disconnection the batteries and going through the process.
