Overheating Transmission on 4x4 long climbs Aux Cooler?
- Replies 8
- Views 2.8k
wil440 3 posts
beautifulisblue 2 posts
IBMobile 1 post
01cummins4ever 1 post
Popular Days
Have the valve body modified for lock up in any gear. Problem solved. Temps will fall. The only reason it gets hot is climbing grades with torque converter unlocked.
Would you be able to do the same climb in 3rd low locked , if you are using 4th LOW then locking out the OD on that climb will mean it would be in 3rd and would tend to be more in Lockup 3rd than torq
Your in 1st gear and never going to get lock up. The trans doesn't shift to second until around 18mph. Get a Derale 15870 fan cooled heat exchanger; about $170-$180. https://www.bing.com/sea
Hey folks need advice on how effective adding a aux trans cooler will be to keeping my trans temps in check,
I bought my 2001 with 300k from my uncle in law. He was the original owner and always serviced it at my father in law's shop. I only using for hunting, camping and occasional trailer hauling trips.
I'm a park ranger in Nevada and love backcountry hunting, climbing, mountain biking etc... My favorite spot involves a 45+ minute climb in 4LO to get up a series of switchbacks from 5500' to 8000'. The transmission, and eventually the motor gets hot. Trans 225+ motor 210. Juice will read the temp sensor I installed in the transmission on passenger side (I know it's not ideal) but also a factory reading that's often 5 degrees hotter, so I run the hotter reading on my gauges.
I pulled the radiator, trans cooler, evaporator when I first got it and cleaned it as it was gunked up and extended the blow by hose below the axle. I've replaced the water pump, thermostat (190), and coolant. I also just replaced the trans cooler with a mishimoto one. On the highway in Vegas I run 156 degrees on the trans, maybe 165 up a hill. The trans would also get hot in 100 degree Vegas just idling for a long time (waiting at the dump). I also replaced the fan clutch twice, once with a cheapo, then with a better brand to be more confident.
It hasn't been hot since the new trans cooler, but I'm thinking of adding a fan aux cooler. I'm getting pack llamas this year and will be hauling a small stock trailer often on rough and slow roads, as well as a stock rack for really rough areas. I'm a backpack hunter so need to get to the wilderness trailhead, then hike in and camp. Looking forward to llamas hauling 80 pounds each for me and not packing elk out solo anymore!
I've got a big front bumper I'd love the mount the trans cooler in the hole where a winch once was to keep the lines short, but can do the under the bed as well. My question is, how much difference should I expect from the aux cooler going slow over a long period of time? I love this truck and since I only put 8k miles a year would love to run it for a long time.
Edited by beautifulisblue
