- Replies 8
- Views 1.8k
Bullet 3 posts
Ravewolf 2 posts
Mopar1973Man 1 post
01cummins4ever 1 post
Ok. So long story short, I tried to swap the old 150 injectors into my truck after I went through and set all the pop off pressures with shims(diesel class project). They're pretty much junk, considering they do nothing but just smoke out everything behind the truck. I ended up going back to the stocker set I got from a good guy from here (name escapes me atm, but thank you again amigo). Had hell getting the truck started again, which I think was because I backed the truck into my spot at home, and it was leaning back slightly (the road has a crown). I got a friend and he helped me get her going again, but as it was idling, it started pouring fuel out of the bottow. We traced it to the old feed line to the old lift pump, which was just pouring fuel out of the end. Now as long as I've owned the truck, this line has never leaked a drop. Bone dry. I figured the old owner was too lazy to delete the old line after putting in the FASS. Now, there shouldn't be a pump in the tank on a 98, right? The 24v just used the engine lift pump, right? If that's the case, why would fuel start pouring out of the old line? I was going to just pop the old line off at the tank, and try to cap it with something, would that work? I really don't want to drop the tank if I don't have to.
