Broken Alternator mount
- Replies 10
- Views 3k
dripley 3 posts
Ironforger 3 posts
Tractorman 2 posts
Mopar1973Man 1 post
Popular Days
You guys need to eat your wheaties before tightening up the bolt
340,000 on original alternator and no issues, BUT very early in its life that very bolt was loose. I tightened it and it never loosened again. That bolt has to be tightened to the point of distortin
Interchangable. Bosch and ND alternators will both fit. I just had this happen on my landlords truck at my other shop. Did the W-T ground wire and pulled the alternator and the nut broke
Damn was getting ready to do the WT ground mod and noticed the upper mount tab is broken on my Alternator. It's a bosch.
Are the bosch and denso alternators interchangeable? I've been shopping around for a replacement but seems to be some confusion about the correct alternator, depending on the eighth digit of the vin. ( in my case it's "C")
Advance auto has the actual bosch alternator (based on the alternator part#) but the listing says it's for trucks with a vin: 7 https://shop.advanceautoparts.com/p/bosch-premium-100-remanufactured-alternator-al6400x/20851271-P?navigationPath=L1*14920|L2*14999|L3*15587
Rock auto has an alternator for vin: C, the listing says its a bosch, but the pictures are denso. https://www.rockauto.com/en/moreinfo.php?pk=5778228&jsn=3
Rock auto also has an alternator for vin: 7 and the pictures of it are bosch: https://www.rockauto.com/en/moreinfo.php?pk=273175&cc=1441320&jsn=2096&jsn=2096
I called a dodge dealer, they said item is discontinued but at least gave me the part# 5104772AA BUT a google search of that number brings up a denso alternator.
A search of the actual part number on my alternator brings up a bosch: 0124525005
Which one should I use? Why is it everyone says my truck vin: "C" should be denso, but my truck has a bosch? Ok so there is a chrysler emblem on my bosch alternator, but who's to guess if it's the original factory alternator. Sure is old and beat up looking regardless.
While I was in there I noticed the large positive cable that connects to the alternator (B+)? was rubbing against the top of the alternator body, wire insulation partially worn through. Glad I caught that before shorting out. Pictures:
