Pristine CTD. Extra cab, short bed, 2wd, SLT. Factory tow/haul package, leather heated seats, heavy insulation package. Rebuilt HX 35/40, Dap injectors, full gauges, PacBrake, Dynamic Transmission vb/servos/accumulator/strut/band/triple disc. Soft tranny lines, 40k trans cooler, lift pump, gooseneck hitch (never used), class 5 tow hitch, tonneau cover, air bags, re- geared to 3.73’s, 3rd Gen brakes with 17" rims Rust free CA truck located in Chico CA, 100 miles north of Sacto. I built this to
Price: 16000
Looking for some advice, about to pull the trigger on the purchase of a FASS 165 lift pump. Currently the trucks fuel system is completely stock with the stock lift pump being in the engine bay still.
Do I need 1/2" fuel hose or does the kit come with it? I keep seeing "big line" kits on @dieselautopower website and want to make a single purchase and not regret having a better supply/return system.
I've read that other members are using their stock fuel filter in conjunction w/FASS lift pump system, is this correct as any added protection I want to take advantage of? Would I require a "Big Line" kit if I went this route vs. just using whatever FASS sends in the box and bypassing all the stock system.
I plan to upgrade injectors later when I go with a bigger turbo and want to ensure the supporting system is ready for those upgrades. I plan to buy the VP44 stealth cover and quad with the purchase of the FASS lift pump. Anything else I should grab while my wallet is open?
