Larger fuel line w/FASS 165GH
- Replies 9
- Views 2.6k
jtrakel 3 posts
dripley 2 posts
dieselautopower 1 post
pepsi71ocean 1 post
Looking for some advice, about to pull the trigger on the purchase of a FASS 165 lift pump. Currently the trucks fuel system is completely stock with the stock lift pump being in the engine bay still.
Do I need 1/2" fuel hose or does the kit come with it? I keep seeing "big line" kits on @dieselautopower website and want to make a single purchase and not regret having a better supply/return system.
I've read that other members are using their stock fuel filter in conjunction w/FASS lift pump system, is this correct as any added protection I want to take advantage of? Would I require a "Big Line" kit if I went this route vs. just using whatever FASS sends in the box and bypassing all the stock system.
I plan to upgrade injectors later when I go with a bigger turbo and want to ensure the supporting system is ready for those upgrades. I plan to buy the VP44 stealth cover and quad with the purchase of the FASS lift pump. Anything else I should grab while my wallet is open?
