1967 Chevy C50 farm truck
- Replies 9
- Views 9.7k
Doubletrouble 4 posts
dripley 2 posts
Mopar1973Man 1 post
Royal Squire 1 post
Just thought I would share what I'm doing with this old girl. We bought this to use as a grain truck/dump truck around the farm. It was cheap and it works so it fit the bill.
Yesterday I was trying to get the heater working. I found exactly what I expected. The heater box and blower was converted to a mouse condo. The blower motor works when tested out of the truck. I believe the switch may be bad, or a wiring issue. It had no power when in the truck. I removed it to inspect and found the mouse house. Then removed the entire heater box from under the hood to find even more. I'm now in the process of cleaning this all out and replacing heater hoses since they were brittle and broke when moved out of the way.
I will be replacing the hoses today and cleaning things up a little more then on to the heater controls in the cab. The switch lever for the fan seems to be froze up. Then test the switch itself. I'd like to get heat going for the fall harvest this year. Also need to haul some stone in for the driveway.
