in tank fuel pump amp draw help
- Replies 9
- Views 2.1k
dripley 2 posts
hdpwipmonkey 2 posts
shade tree fixer 2 posts
IBMobile 1 post
Popular Days
I looked in the FSM and for the stock lift pump on the side of the engine, it said normal current flow was 12A. I'm surprised it is that high...
Well i will not scold for buying the pump. I paid big bucks to Dodge for one about 9 years ago. If I had to depend on for anything but getting to and from work i would have been in bad way. If you re
Amp draw test. https://www.hagerty.com/media/maintenance-and-tech/measuring-current/ A cheap Harbor Freight multimeter will work. https://www.harborfreight.com/automotive/diagn
https://www.oreillyauto.com/detail/b/precision-fuel-pumps-4602/fuel---emissions-16775/fuel-pumps-tanks-16472/fuel-pump-strainer-16843/fuel-pump-12322/83db8e3f0135/precision-fuel-pump-module-assembly/a30060/4614935 Is there a way to figure how many amps this will draw, i need to make a harness for it. (i would also appreciate that everyone doesn't scold me for buying it as i have already installed it and i need to make some money with this truck before i will shell out the cash to go a better route)
