Idles fine, sluggish response, no boost, no codes
- Replies 9
- Views 2k
jstills 3 posts
hdpwipmonkey 2 posts
Mopar1973Man 1 post
Tractorman 1 post
Popular Days
found the issue...not above admitting it even though I feel really dumb....like really dumb. Don't forget to pull your rag out of your intake horn when you plug it to keep from dropping st
Glad you figured it out.
I cleaned my motor ounce with sewer cap on the turbo. With filter in the back seat it didnt want to run at all.
Let me first start by saying this website is an incredible resource and I'm very grateful for all the great content yall provide.
During the extended time at home during COVID, I did a few projects on the truck and now I'm having some issues.
1) Installed a FASS 165 with G&R sump
2) Replaced my old nasty battery cables with a set from custombatterycables.com
After both the projects, I put everything back together and it starts and runs fine, but doesn't produce any boost and has a fairly sluggish response. There is a decent amount of smoke if I get much above 2000 rpms. I still have steady constant fuel pressure at around 18 psi with the new FASS. No check engine light, but ran an OBDII code reader and it didn't report any codes (it's a bluedriver code reader, bought it for this diagnosis as it seemed to have a good reputation, but I guess there could be a possibility that there are codes its not reading as I have nothing to compare it to at the moment).
Prior to the above projects everything was great. I've been digging all though the internet and this site trying to find the cause of my problem and I just can't seem to come up with any solutions. From reading on this site, it sounds like there is a possibility it could be an issue with the MAP or data link sensor, which I tried to investigate but nothing appeared to wrong with it.
Things I have tried/investigated:
-no obvious boost leaks
-no glaring issues with the data link or MAP sensor plugs or wiring
-no OBDII codes
-turbo spins freely
-Unhooked the quadzilla but it still behaved the same
-rechecked my battery cable wiring and everything seems fine
-reflashed the quadzilla and reinstalled (everything the quadzilla reads appears normal)
-My next thought was to change the MAP sensor, but I was curious if there is any way to tell that it is bad vice just blindly replacing.
-Also have dealt with bad injector pumps in the past, so understand that this could be a culprit, but ever since I got a new VP44 a while back when mine failed, I have had a raptor lift pump so I don't think (well really just praying) that the VP44 isn't the culprit. But if it was failing would there be codes/other symptoms to point here? seems like it's getting fuel so I haven't dug too deep into this.
I'll take anything at this point as I'm currently stumped. Again, thank yall for the content and all the great information.
