- Replies 30
- Views 5.5k
trailhead 11 posts
Bullet 11 posts
dripley 2 posts
Dieselfuture 2 posts
Everything is back together. The tunes I downloaded for the quad are working great with the injectors. The new hx35 has delivered 32 pounds of boost and I haven’t even put the pedal to the floor or d
Since there's no contamination in the fluids I'd look at fuel issues...injectors and injection pump. If they are originals then the injectors are surely beat and the injection pump is not far from it
I'd say 7x10 with proper tuning be fine with stock turbo, you'll never have to use wire tap, it'll have plenty on level 3 can buss only. As long as they are popped to 320-325 and I'd go with vcos. I
2001.5 6 speed was driving home just fine when I noticed white smoke coming from the tailpipe. If I hit the skinny pedal I got a lot of black smoke. Pyros were a tad high but not dangerous. Boost normal. Fuel pressure normal. Temperature oil pressure all normal. Even felt like normal power. Regardless took it easy for 5 miles to my driveway. Shut it down. Turned the key. It fired up. Same smoke issues. Shut it down. Turned the key. It rolls over like there is no fuel. Fuel pressure gauge is still good. Popped the hood. Recently had the fuel pressure gauge installed and noticed it was weeping a bit. Thought maybe I was getting air in the fuel system. Tightened up a few fittings then turned it over again. Still sounds like no fuel. Figured I may have lost prime. Googled how to prime a vp44. Saw a couple posts about loosening up injectors 1,3,4 and bumping the key to get fuel through. So I loosened up 1,3,4 and bumped the starter. I did not have any intention of holding for any length of time. Just bumping it. It sounded horrible. Clunking. Chunking. I don’t know how to describe it. So I tightened 1,3,4 back up and went back to the key. Now my starter sounds like it won’t engage. I pull the starter out and the shaft is broken in two. Went to town. Bought starter. Installed starter. Have not turned the key. That’s where I’m at now. Any advice?
