- Replies 11
- Views 4k
jw9424 4 posts
Mopar1973Man 2 posts
dripley 2 posts
wil440 2 posts
Can the cam position sensor be tested with a DMM for the correct resistance? If so, what should the value be? This is on an 01 2500 auto. Trying to track down what's causing a P1488 code among others. The trouble-shooting procedure tells us to replace the cam position sensor but we've done that a couple times. Any help would be appreciated. Thanks.
