- Replies 8
- Views 7.1k
Mopar1973Man 2 posts
Haggar 2 posts
Nascar 1 post
Joe_Pool 1 post
Hi Guys. I have a ton of mechanical experience but very weak in electrical. I hate it. Bought a 1999 Cummins for my daughter that will be turning 16 in Sept ( she will be paying me back for the truck, lol ) and even with new batteries, if it sits for a week or more, the batteries drain to the point it will not start.
I have tried to research this problem & have eliminated the seat belt modules are not the problem. What else could it be ?
Any help would be much appreciated.
On a side not, it also does what I think is a weird thing. Sometimes when you turn the key to the on position, the wait to start light doesn't come on & no matter how long you crank, it will not fire. I know the ambient/engine temp sensor monitors this but if you turn key off & then back to on, the wait to start light usually comes on & once it goes off, it fires up right away. again even with engine warm, if the wait to start light doesn't come on even for 1 sec, you can crank to the cows come home & it will never fire up. Just thought I would throw that in here, incase it has something to do with battery drain ?
Other than that, everything else works as should.
Thanks
Edited by Me78569
