Edge Comp
I found a guy with an 02 edge comp for sale. Just wondering if anybody knows if it'd work in my truck. I plan to call edge but thought I'd see if anybody here knew first.
  • Replies 16
  • Views 4.3k
There are 2 different edges one for 01-02 and one for 98-00, so no it will not work on your truck.
It will work, It just needs and adaptor harness for the MAP sensor which Edge sells.
I was told it would not work because of different programming and its also a different part number. I am usually wrong though so check with edge.:cookoo:
I've heard the same thing something about voltage diffences in the MAP sensor... :shrug: I agree with Whitelightnin' give Edge a call they will tell you for sure...:thumbup2:
Yeah I heard same as W+F - just requires a new harness. Assuming that would address any voltage diff ?? :shrug: So thats 2+2 - or 50/50 crapshoot ..... puts you right back to where you started :lmao2: think edge will be the answer make sure to post what they said back here !! :thumb1:
I talked to edge today and it's a no-go. Said the map sensor has a different connector and the voltage is different. No mention of a different harness.
After seeing this, I remember that the 01 and 02 comps are the same but the harness is different between those 2 years.
Yeah the MAP sensor plug...
That sucks!
If your still looking for a comp, there is a guy on CF selling one for $250. http://www.cumminsforum.com/forum/98-5-02-2nd-gen-all-products/311899-smarty-edge-comp-tdr-magazines.html
I'm actually not sure what I'm looking for. Can't decide so I'd like some ideas on what is good and what is not. Right now my truck is in the tranny shop:banghead: so i won't have money for this for a while but I'd like to know for when I'm ready.
Man if I was doing it all over again - I would have followed mikes original advice, and it also depends on what going on with your tranny - if your having a new one or built up etc ?? In order BHAF + outerwears - $80HP Valve Body ..... $100-300 depending if you do it or have one sent etcNew Single Disk TC - I went tripple - but probably overkill for 350HP - $600and a low end chip ..... like Puck, EZ :) $2004" exhaust (straight if you can) - $100- $400 depending and stopped there - about $1200 for a beefed up tranny and an extra 60-90 HP over stock good for all situations except racing and dumping heaps of fuel if you needed more ...... then get a built tranny and TC in one go - performanceinnovations or revmaxx - $3k + Edge Juice or Quadzilla ~ $400 second hand beyond either of those 2 scenarios and it gets expensive .... new turbo's, big injectors, head studs on TOP of everything else:thumbup2:
Man if I was doing it all over again - I would have followed mikes original advice, and it also depends on what going on with your tranny - if your having a new one or built up etc ?? In order BHAF + outerwears - $80 HP Valve Body ..... $100-300 depending if you do it or have one sent etc New Single Disk TC - I went tripple - but probably overkill for 350HP - $600 and a low end chip ..... like Puck, EZ :) $200 4" exhaust (straight if you can) - $100- $400 depending and stopped there - about $1200 for a beefed up tranny and an extra 60-90 HP over stock good for all situations except racing and dumping heaps of fuel if you needed more ...... then get a built tranny and TC in one go - performanceinnovations or revmaxx - $3k + Edge Juice or Quadzilla ~ $400 second hand beyond either of those 2 scenarios and it gets expensive .... new turbo's, big injectors, head studs on TOP of everything else:thumbup2:
Thanks for the advice. Just wondering what the torque rating of my truck would be? I'm getting my tranny rebuilt at a very reputable shop. He's doing upgrades for towing and said the torque converter he puts in is a twin disc and rated for 900 ftlbs.
ok =- here's where I get into trouble as I don't fully undersatnd this but will give it a shot until you get better adivce
horsepower = torque * rpm / 5252
http://dodgeram.org/tech/dsl/Facts/01ISBspecs.html
So at the moment you have a 230 HP truck (stock) give or take. Lets say with the baff and an +60HP chip you reach 300HP then at peak HP (2700rpm) you are basicaly
300=x*2700/5252
so torque would be around 583 ft lbs with a small chip ......... and upwards from there.
People say you lose 10%-15% of whatever you calculate in the driveline as well - makes sense to me.
Anyway - unless your going crazy - with a new built trans as well as an EZ or smary or XZT+ - that would be a nice truck for towing and a little mileage. If you go to a 120-150HP chip - then you really need to trust that transmission and start monitoring EGT's and tranny temps as you dump all that fuel. Again - beyond that (injectors/stacking) you will need new turbo and other stuff :)
I would start off with a secondhand or cheap EZ ..... check jkidd or forums ..........and some GAUGES - I forgot to mention that - more imporatant than all the others almost. Probably pick one up around $200. Try it out for a while .... see how it feels and what you think - worst case - pull it and sell it for $150 and then by a secondhand edge comp/juice for around $300-$400. Here you need to TAP your vp44 in order to get the fuel/power.
