- Replies 7
- Views 1.9k
Mopar1973Man 2 posts
Doubletrouble 2 posts
Rotket 1 post
That Guy 1 post
Man its been a weird month. Fuel gauge drops to empty comes back for a few days and quits for good. Find out the float wore out enough to slide all the way up the arm and let the arm sink to the bottom. Then had a ticking front on the passenger side come to find out passenger side wheel joint failed and the proceeded to break a clip and push the cap out will pull bushes out. About a month ago my cruise COAST button failed. I found a used switch on Maccari for $15 bucks, and installed it. Then last night figure I would play a bit on my performance tune and found out my wire tap isn't working (boost capped to 33 to 35 PSI). Most likely the tap screw loosen up a bit broke connection at the VP44.
So what I've got fixed...
