Truck let me down today.
I had the flatbed hitched up to go get some scrap from a friends house, made it 3/4 around my block and got a dead pedal.  I was able to coast back into my parking spot which was nice.  I checked codes on the Edge, got a P0121 and a few others I see on occasion.  The pedal came back after a minute of sitting but now I'm too spooked to drive it anywhere.  I got the explanation of the code from the articles section and will be going through the test steps.  I wouldn't be too upset if it were time to step up to a timbos apps.   I was able to do my scrap run, buddy still had his work truck, 2016 GMC 2500 so we hooked up my trailer and got it done.  I want air conditioned seats in my truck now though.  :cool:
  • Replies 7
  • Views 1.5k
  • The truck oil us fine or whatever you have on hand.
  • Sycostang67
    Sycostang67
    I need to clean the terminals anyhow so I will try it with the batteries disconnected.  I did go ahead and order the Timbo apps anyhow, I do have a trip planned and didn't want to wait until the last
Five minutes in and I'm already pissed off.  I disconnected the sensor and tested the plug with engine idling and got less than 5.5 volts, pretty steady at 5.13 volts.  I'm now trying to test resistance in the sensor and I am getting nothing.  I've tried grounding to the battery,  various locations in the engine compartment, the sensor itself and the meters(all 3 I tried) read nothing.  The sensor bracket is unbolted from the engine, it was the only way I could get it unplugged.  Whatever is below novice, nincompoop maybe is my electrical skill level so any help on how to use these things would be appreciated.  The meters all zero out when I touch the probes together but read nothing at all or OL otherwise.   I am using the ohm setting on the meters.
Batteries must be disconnected when using an OHM meter or you can damage the meter. Just in case you did not know. I hope you find it and keep us posted.
I need to clean the terminals anyhow so I will try it with the batteries disconnected.  I did go ahead and order the Timbo apps anyhow, I do have a trip planned and didn't want to wait until the last minute if I do need a new sensor.
It should be getting to you soon. (New Timbo's APPS).
Keep your battery terminals coated with engine oil you never clean them again. They will never corrode or oxidize.
That did show up quick, just got it installed.  Thankfully I didn't have any of the stuck screw issues I've heard about.  All the voltages checked out so hopefully I'm good to go.  I'll probably take it to work a few times before my trip just in case.
Does it matter what weight of oil I use to coat the terminals?
