Converter Unlock/Lock, but only towing
- Replies 13
- Views 2.4k
jltait 5 posts
JAG1 4 posts
Threadzy 3 posts
Mopar1973Man 1 post
What is your AC noise reading? Have you done the W-T mod?
I was thinking the possibility of a couple old batteries in the fifth wheel. If one has an internal short would cause the alternator to be working hard, at possible full tilt, thereby raising the A/C
@JAG1 @ThreadzyAfter work today, I threw the meter on it again with the AC/blower on full blast. .06 v, so I'm in agreement that the AC noise is the problem. I am going to disconnect the current B+ ca
I have the Timbo APPS, fixed the previous Lock/Unlock issue a couple of weeks ago. Last weekend I hitched up or 5th wheel for a 3 hour trip. With the 5th wheel in tow, the dreaded Unlock/lock cycling came back, especially later on in the trip when the truck was good and heat soaked, or so it seemed. I have driven it to work (30 minutes each way) this week after disconnecting the 5th wheel, and the issue is again gone. I have previously checked for alternator noise, which was negligible. Is it possible that the charge circuit to the 5th wheel is inducing this problem, or possibly the extra heat in the transmission when towing? Any thoughts would help.
