- Replies 8
- Views 2.4k
Mopar1973Man 3 posts
jlwelding 2 posts
Haggar 1 post
That Guy 1 post
I've used a small bottle jack and a 2x6 and spread the frame slightly like an 1/8 inch max comes out easy.
I learned that when I did my clutch job. I used a bottle jack and a board to spread the frame for removal. Then I studied the frame and I realized that the jack wasn't needed and I re-installed the
I don't... I normally clean the splines off with brake clean and don't add any grease to the splines of the input shaft. Just seems to collect dust and debris. Adding to wear of the input shaft. Witho
Ok I tryed searching and not good at it at all. Ive done it several times and cant remember. How do you remove the cross member to drop the trans?
