- Replies 14
- Views 2.1k
Popular Days
I have to agree @Threadzy on finding the problem first. You can flush a lot of cash down the toilet hoping this or that might fix the problem. FWIW my HX35 has 510k on it. Rebuild kits for them are ab
That sounds like the turbo to manifold gasket starting to go. Soot don't always show up right away, I would look real close at that. If it is on the bottom it would be hard to see. Check all bolts on
I’d figure out the problem before I threw money at it.
Hey guys,
Last night I headed home from a buddies house and the turbo (hx35) started making noise whenever I got above 15ish psi. It wasn’t gradual, truck was perfect when I got out and made noise when I got back in. I’ve never heard an exhaust leak on a Cummins or any turbo vehicle but it’s almost like the turbo itself is leaking. At first I thought it was something hitting the turbine or compressor at low rpm but when you get the boost up it sounds more like a leak. Looking around I see no soot on anything under the hood. However, I’m still able to build 36psi which is the max I could before. No extra lag or smoke, no loss in performance that I’d expect from a leak. The turbo has almost no play, only a tiny bit of lateral play when it’s hot. None when cold. The sound is like a ticking flutter that varies with turbo speed but doesn’t happen in single digit boost. I ran the truck this morning cold and didn’t hear it at first but as the turbo got warm it certainly is still happening. I then tried taking the air filter off to get more sound and I don’t think I heard it but the turbo was so loud like that I’m not sure if it’s just overpowering the sound I’m looking for. The turbo spins freely by hand, no noise hot or cold.
I tried setting the air filter on some foam thinking maybe the cage was rattling and that didn’t do anything.
Heres some videos, I’m not sure you’ll be able to hear it but worth a shot. https://imgur.com/gallery/yedFsLT
Thanks, you guys are always helpful and cool
