Need truck to be running better, less smoke
Hello all. So thew truck runs pretty good but I know it's not at it'd potential. I want it to not smoke as much and tune it properly so if I'm driving nicely I can get good mpg but then have power when wanted or needed.
Just bought it about 3 weeks ago.
Here are the upgrades:
stock turbo compounded with a bw s366
225 DAP injectors
Hot Rod VP44
Air Dog 200
110# valve springs
.93 fuel connecting tubes
5inch turbo back exhaust
Quadzilla 4k
Any and all suggestions are welcomed. At WOT this thing makes an insane amount of smoke even when its making boost. I don't think it makes enough boost though as it should and it also doesn't start making boost til like 21-2200 rpms... May be a boost leak on a boot as well. I'm thinking of starting with a new programmer that isn't a damn 4k.. since the fuel stretch by default is twice the max a regular quad can do. I also think the valves may need to be adjusted as I hear a high pitched rattling at idle.
  • Replies 32
  • Views 7.2k
  • ditch the 4k box.  a street driven truck has no place running it.     if the injectors are not DDP brand then you should be able to clean it up fine.         the 125's +
  • Just saw your post today MoparMan and had to subscribe since I think this site will definitely come in handy in the future. So, could you give me some input from my new possible idea for the truck? So
  • a tune for 125's will not be smoke free for 200's or 225's.       Ditch the 4k box get a regular adr box with a tune for your injectors.  with the quad you can tune yourself, with the s
Quadzilla was up and running IIRC was my economy tune set for kill on 7.
Boost leak was man made by remove the hose and the bolt from the manifold.
With a proper tune on the quad a boost leak you will not see big issues since the quad is pulling fueling based on boost levels.    This is because the quadzilla is waiting for boost to add fuel.  each psi level is a  "step limit " on the amount of fuel.
However with an edge or a bad tune on the quad the tune is effectively trying to add fuel to get boost up, which is the opposite of what a proper quad tune is doing.
OP might be seeing a big difference due to the boost leaks depending on how the tune is setup for his truck.  If it is a heavy fuel tune then I could see egt's and smoke as a result of a large number of boost leaks.
Well **** then I wonder if it's just the tuner that's giving me most of my issues. We sprayed soapy water down on all boots and what not and the only leaks we found were on the intake horn (custom, weld had 2 holes in it :duh:) and proper bolts weren't used to bolt it to the grid delete block. Then, there was another leak near cylinder 4 or 5 on the intake plate. I'm guessing the gasket may have blown or it's not torqued down. Maybe its warped or over-torqued. The guy with the 64mm turbo was building boost around 1700rpm and mine don't build til like 21-2200. He was also able to rev it and build some boost. I don't get anything. Should I try to tune the 4k down super low on fueling side and see if that makes me build boost earlier and help the engine not bog down in the lower rpm's? Also, I found out it's not a stock turbo so not an hx35. Previous owner I texted the other day and he told me the 2nd turbo is a 364.5/475. The other turbo is an s366. My apologies for not mentioning this new information earlier.
s364 s475 is a 64 75 twin setup.  Not sure where th s366 is coming from as you have now listed 3 turbos.  s364, s475, and s366/
You need to figure out what you have before you do anything.
the 4k is a race only box and shoul dnot be on a street driven truck.
Edited by Me78569
Yeah when I texted the previous owner the other day that was the setup he told me. Not sure why in the ad it listed an s366 on there. Maybe that was a standalone turbo before he did the twins? I'll check to see if I can pull the S/N's off both turbos and find out what exactly they are because I need to get this truck sorted out asap..
When I first got my truck and had a lot of questions I called PO and tried getting some info out if him just to find out later he had no clue on what he was talking about. Thanks to this place I got where I am today.
you bought a truck geared towards high rpm fun rather than day to day duties.
I would be selling the twin setup and replace it with a single turbo setup and some 7 x .010's rather than the 225's and ditching the 4k box.
I would do a 62 sxe or a 57 sxe depending on how much hp you want.  if you want 500 hp then a 62sx if you want 400 hp then 57sxe
What about that 64mm I mentioned earlier that a guy where I'm located was down to trade setups for? I'd do the 7x0.10 injectors and a standard quad box
your smaller turbo is already a 64.  you are trading him for the same turbo, plus he gets a 2nd and the piping.  Not exactly a square trade in my mind.
Yes but his is brand new. I'm not sure of the actual condition of my current turbos. Plus, I bought the truck with them so I'm not concerned about trying to get money out of it. I just want it running better tbh. He's also gonna be sending both of my turbos out to get rebuilt if we do make the trade.
Do what you want, you aren't gaining anything to any of your goals.
That 64 isn't even a good fit for what you want.
Sell your stuff and get a 62 sxe if you want 500 hp or a 57 gxe if you are happy with 400.
  • 3 weeks later...
