- Replies 5
- Views 3.7k
Mopar1973Man 1 post
Dieselfuture 1 post
Towrigdually 1 post
That Guy 1 post
I have not seen a lot of info on these, so I thought I'd ask you guys. Will I see any benefit in putting traction bars on my truck? I know they keep the rear axle from twisting, not that I do burns outs and stuff, but I've heard it helps a lot with washboard roads and smoother take off with the clutch from a stop. Ive gotten used to it, but man there are still times the clutch likes to shake the crap out of you, usually when reversing up a slight hill (It has done this before and after a new clutch.)
What are the benefits?
If im towing of hauling a heavy load, is there anything I need to keep in mind in regards to the bars? Like are there situations where they need to be disconnected for some reason.
I'm not a big suspension guy, so pardon me if these questions are dumb....im stock height with 265 tires, and I'll be keeping it this way.
