- Replies 6
- Views 3k
Evan 2 posts
Mopar1973Man 1 post
IBMobile 1 post
Doubletrouble 1 post
Popular Days
I did mine with the swivel lines and didn't have to pull the hvac box out. You have to work the lines through the fire wall as you drop the heat core in the box.
Heater cores in. Then decided to service and rotate tires. Turbo is looking good and clean Definitely putting heat out the vents now.
Wasn't as horrible as I thought. probly an hour to get it out.
I am reinstalling with heater hose adapters. Instead of tearing the truck apart more.
I may see if i can finangle the swivel lines through but on a quick look in the dark I don't think they go without do the other 3hours of disassembly
