Swapping a nv 4500 for a 5600
What is involved in replacing the nv4500 with the 6 speed? I cant keep a 5 speed evidently, I believe they just skimp by on parts or something. The only other thing I can think of is I'm running the amsoil synthetic.
  • Replies 26
  • Views 17.2k
  • The over fill on the 5600 was to get more oil back to the 6th gear bearing as have always understood. Had nothing to do with the Sychromesh being thin. At least as far as I have read. Last time I chec
  • Syncromesh is NOT supposed to meet the GL-4 rating, so that’s a good thing. Don’t try to make it meet a spec it’s not designed for.    Not to mention GL-4 isn’t a thickness spec and there are G
  • No, power has nothing to do with syncro's. The clutch is released (no power) when you shift.   Syncro's can be bad (poor quality) from the get go, bad shifting habits, the wrong oil type or
16 hours ago, Doubletrouble said:
@Mopar1973Man, do you think that the sycro failures, even though defective, would have lasted longer behind an engine with less hp/tq than what your putting out?
Didn't even last 1,000 miles. Power was not the cause. Still got the same power and same brass syncro no issues. AH64ID will say my fluid is the cause of the failure. Nope. Not at all Again I tried to change to something different and like Abe told me if I don't choice from his list of fluids the warranty would be void at that point. I've had really good service from the Mobil 50 trans fluid it is thicker but it clings to the bearing and gears much better than the factory fluid that was watery and thin. Still its a quality synthetic and its is GL-4 rated.
Now when you study guys that do true racing and using higher power than me the stock or factory fluids have to be changed out for thicker fluids for protection. Thinner fluids do promote better shift quality but thicker actually clings to gears and bearing much better under heat. The only thing that is bad is come winter my transmission temp falls to near 100*F or lower most days so the fluid is thick, hence why I don't want FAST coolers it would make things much worse.
Still zero shifting issues at even -20*F to -30*F I've seen last winter. Then flip to 110 to 130*F in Arizona trans temp was still below 200*F easy even pulling my RV on a 7% grade in Arizona heat.
The problem is Autozone is is either a trip to Lewiston or Boise (whole day lost - 6 hours driving), O'Rilley's again a trip to Lewiston or Boise (whole day lost 6 hours driving), etc. Again the only local part store I've got is NAPA on in McCall is 70 miles round trip or to Concil, ID which is 104 mile round trip. I've also got a delivery to the house on Tuesdays I just gotta call Kevin in Council and it on my door step in the morning on Tuesday. All shops up here typically use 99% NAPA parts there is nothing else. Just like the Chevron station in Town yup, NAPA only.
How do I know this so well. I just left for Lewiston, Idaho yesterday for food shopping and by the time I got done with everything and got home its 8pm. Mostly food but I did stop and get a jug of Synthetic oil (5w-20) for Eileen's car and a NAPA filter. Did not really save much on the parts but since I was in town why not get it. (Outside my network - different owner)
My account with NAPA (Council - McCall) I get some pretty good discounts. I bought 4 gallons of standard green anti-freeze (NAPA) for $5.99 a gallon. Even done a coolant flush on a 6.7L not to long ago and it requires Dexcool I got is for $8.99 a gallon. My discounts are past on to me by the amount of parts I buy per month. More parts, better discounts. I've done it a few times buy my oil for my truck and get the oil filter for free.
Here is current public price... For 3 gallons would of been $56.97 before taxes.
Then what I paid for it... $8.99 a gallon for $26.97 before taxes! Saving of $30.00 even! Absolutely nothing wrong with NAPA goods... For me, better prices!
 Those are some good savings over regular price. I should talk to my local napa store about an account. They have asked if I wanted one several times. Might take them up on it.
 We buy plenty of stuff for not just vehicles but we also have a small farm, several tractors and other equipment to maintain. Most if the tractors are antique and napa is pretty good about locating parts for them as well.
So to bring this back to Swapping transmissions. Still in all just for @jlwelding I would look both way again at rebuild prices of NV5600 and the Nv4500 then look at the replacement cost of both for clutches.
:iagree:While I do like the 5600, if going for a change to it you have to weigh the options. The 5600 is definitely a bigger expense to get into. I am sure I paid a bit of a premium for it when I bought the truck. Just like the $5k extra I paid for the Cummins.
Yeah I could buy several 4500's for that cost. lol
I'll just keep waiting, they still haven't sent warranty trans. Been 8 business days.
Freight is slow now... I'm still waiting on my pedal assembly for the other 1996 Ford F-250 Powerstroke I'm working on too. Shipping is slower with people getting sick with COVID and lack of crews now to move packages. Heck I ordered a brand new LG dishwasher on Thursday it will be sometime in February before Home Depot has it in stock.
Yeah I did a bit of digging even on my part the price differences between a NV4500 and NV5600 are insane. Still the NV4500 is cheap and more common for parts. You could upgrade the NV4500 input shaft to a NV5600 input shaft. Even with all I've done I've Never broke the input shaft. Never had a 5th gear nut issues either. Don't let that turn you away. As for bearing failure from lube never happened yet. Metal fatigue... Yup plenty of that. First was the mainshaft that broke at 3rd/4th gear. Had the OEM shaft replace with a Torque King Upgrade shaft. The 5th gear bottom was replace because the hard face was wore through. Then pilot bearing fell out of the flywheel on to the input shaft ate the input shaft bearing and the tip of the mainshaft. Which put stress on the 5th gear since the top gear was OE yet stress took the teeth off. Never had a oil failure yet. 423k miles and ticking...
I would still hold on to the NV4500 and then take the driver side PTO cover off and install 1/8" NPT bung and install a trans temp gauge. With the amount of heat in Texas you would be a good candidate for the Mobil 50 SAE Trans Fluid. Basically its straight 90 weight gear lube. GL-4 rated synthetic. With the Texas heat you should stay away from thinner fluids. Still don't use any FAST coolers yet too. Winter time my trans temp stay pretty low mostly below 100°F in the winter. My typical summer trans temp floats 140 to 160°F without coolers. Even towing I rarely get above 180°F. Even in Arizona topped out at 200°F on a 7% grade in 110°F weather. Little warm for my liking but nothing dangerous. Got get past 230°F to be dangerous.
Then when I upgrade from 265's (31.6" tires) to 245's (30.5" tires) it reduce stress on the transmission and driveline. Changed the final ratio from 3.55 to 3.69 This mod change the trans temps and made them cooler. Made more power towing on grades with less heat. At 66 MPH I'm a prefect 2,000 RPM
