Thuren alignment specs?
- Replies 27
- Views 14.1k
dieseldon 12 posts
Haggar 5 posts
Mopar1973Man 3 posts
Dieselfuture 3 posts
Don, The normal toe for our trucks is +/- 0.1 degrees. So he has tightened that up a bit. Same with the castor. He is in the right range, he just removed the -1.0 degrees the factor al
Again, if Schwab admits it drives off and won’t redo the alignment then you should get your money back. Why didn’t they tell you the ball joints were worn the first time?
do the cam bolts look like they were touched recently? They SHOULD have been adjusted during your front end alignment. It sounds like to me, that you got a "toe and go". Sorry you don't have good p
I have a question for anyone that might come across this that has the T -stearing linkage/tie rods on their truck.
Any experience with the "Thuren alignment specs" ? Very specific that you have t-style linkage or disregard spec's, 0.0 - 0.05 toe and 3.8 - 4.2 caster, I believe the emphasis is on the 0.0 toe?
Just had it aligned and NOT happy with factory spec's, always holding the steering wheel to one side or the other, back and forth, back and forth...
Anyone know a good alignment shop in Boise/treasure valley area?
Thanks!
