47RE manual shift lever problem
- Replies 13
- Views 9.2k
LorenS 5 posts
Mopar1973Man 4 posts
Threadzy 2 posts
Me78569 1 post
Popular Days
Another member on here had an issue like that I believe. Something came loose on the inside on that shaft. He dropped the pan. Said it was an easy fix. Sorry so vague. If I can find it on here I’ll po
Not sure if this is your exact issue or not. The end of page one it starts I believe.
I had the issue with sloppy shifting and it was part number 3 in the top diagram. there is one on either side of the rod that centers it.
It rather suddenly became obvious I have a gear selector issue, very sloppy trying to select a gear.
Any suggestions? I looked in the Parts diagrams, looks like perhaps a retainer fell off? No leaks. Bolt "#21" in diagram is there and tight.
Photo of internal shift portion from Moses Ludel writeup. Is it possible/likely that clip he shows is my problem?
Edited by LorenS
Added parts diagrams and Moses Ludel photo
