24valve Vp44 bottle jack injector pop tester
- Replies 9
- Views 4.8k
Doubletrouble 4 posts
Mopar1973Man 2 posts
Dieselfuture 2 posts
dripley 1 post
Popular Days
Nice. Could you write an article on how you built that exactly. I would love to have a cheap test stand for 24V injectors!
Nice job! Is there a way you could check your injector readings against a known accurate gauge to be sure it's as accurate as possible, or calibrate it somehow?
So I've been debating about making this thing and finally decided to do it. Had some extra time on my hands and after looking at whole bunch combined ideas here is mine. I had a set of 75hp injectors I got in 2014 that I used for about a year so roughly 7-8 k on them. They came poped at 310 bar and I just checked one of them and it's popping at 260 if I do it quick, meaning keep pumping pressure and it just goes pop pop pop few times a second, now if I go slow it'll pop at 290. The gauge I'm using is a cheaper china special, but it liquid filled. I'm going to check all of them here soon when I get more time just to compare. I also got a shim kit from dap that I'll play with so when I pull my 7x10 some day I'll know what to do. So this first injector is popping low but the pattern looks good not dripping ether. I'll probably get a more expensive guage that's 4-5" instead of 2.5" for better accuracy too. This one seems like it's working good though for being a $15 one. The expensive part was the adaptor for $100 I had this 4ton bottle jack fo a long time, it is also made in china. Had to by some fittings from local hydraulic place $20 and was lucky to know a guy that works at CAT in parts department, I asked him if they had some 14x1.25 injection lines because that's the adaptor threads and he said you won't believe it but I just seen our mechanic through some away today. So I drove down there and he already pulled it out of dumpster. Guess they don't reuse lines when they fix things. Line is like brand new too. So here are some pictures, wasn't that hard to build, had a pin hole in my weld I had to fix other than that it works.
