- Replies 26
- Views 8.2k
Mopar1973Man 10 posts
01_Cummins_4x4 7 posts
Silverwolf2691 4 posts
Me78569 3 posts
dont make any decisions until they test them for you. For %99 of the guys out there stock pop is fine.
The ho pump is not causing the issue. Ho's are plenty fine with 100's
Same 310 bar is what the injectors are suppose to be set for. Right out of the Dodge FSM...
I just got my replacement injector yesterday since one of them from the original 6 was causing a severe miss at idle, like the pop off pressure wasn't set right.
I put the injector in my 01 Dodge Ram 2500 Cummins HO 6 speed 4x4 that I bought 12/5/2020, and it doesn't miss now, but it lopes like it has a cam in it. Unbeknownst to me as this is my 1st HO Cummins (my two previous were '99 Ram 2500 Cummins with a 47RE trans and SO VP44 pumps. I just found out that my Industrial Injection VP pump that is on my pickup when I bought it, is the HO pump. Apparently since the HO pump is a low volume/ high pressure pump, it can't provide enough fuel to feed the 100 HP injectors, hence the idle not being as smooth as normal. I removed them last night and installed my stock Bosch injectors and it runs smooth like it did before I installed the 100 HP injectors.
Since I only put 10 miles on the injectors, can I send them back and exchange them for 75 HP SAC injectors?
Thanks,
Doug
Edited by 99_Cummins_4x4
